2002 BMW 540i grabbing
2002 BMW 540I
120,000 MILES • V8 • 2WD • AUTOMATIC
PISSYW/MY540I
I have had my car in the shop multiple times and had the brakes looked at each time. Everytime they say I have 70% left on the pads and the rotars are fine. Occasionaly when I am doing a slow stop, like at a stop light I see in the distance as I slow under 5mph my brakes will shudder and eventually grab at about 1-2mph.
Jun 14, 2009 at 1:02 AM
DOCHAGERTY
  • 9,606 POSTS
Has the car been scanned for faults?
Jun 26, 2009 at 1:26 PM
DR LOOT
  • 2,311 POSTS
having an awesome car like that!! I am wondering who did the last brake job with 70% of brake pads still left? did they do the brake job properly? did they put the right pad on? did they turn the rotors? and things like that. I believe the pads have been overheated, and they are glazed, you will need to remove the brake pads, sand them down Just a little bit to remove the glaze, and ruffian up the rotors with like some 80 grit sandpaper, and then tell us if you have the same problem.
Jun 26, 2009 at 4:40 PM
