2001 BMW 540i will not start
DARRYLDHILL21
Transmission problem
2001 BMW 540i V8 Two Wheel Drive Manual 100k miles
just put another transmission in and will not start
Dec 16, 2009 at 3:34 PM
  • 75,988 POSTS
An engine will start without a transmission -you probably disconnected a wire somewhere-Do below and determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 16, 2009 at 4:57 PM
