2001 BMW 540i Spark plugs / PCV location
2001 BMW 540I
CHEDLEY
  • 6 POSTS
Engine Performance problem
2001 BMW 540i V8
Re: 2001 BMW-540-i:
Where are the spark plugs located in this engine?
and where is the PCV ?
Would replacing the PCV, the spark plugs and the fuel filter improve the performance of this 2001 BMW-540-i V8 engine?
Feb 5, 2009 at 8:08 PM
DOCHAGERTY
  • 9,606 POSTS
Plugs are under the valve covers and the PCV is the plate on the back of the intake manifold, go to Realoem.com for the plate, also get the throttle plate profile gasket and intake manifold gaskets along with the valley pan too. They all have a tendency to fail at about the same time.
Feb 6, 2009 at 12:43 AM
CHEDLEY
  • 6 POSTS
When replacing the spark plugs, should you also replace the connector boots and ignition coils of the spark plugs? and the valve cover gaskets?
This car has never been tuned up, and has close to 100K miles.
Feb 6, 2009 at 4:33 AM
DOCHAGERTY
  • 9,606 POSTS
At 100k miles there are many reasons to remove the intake manifold and replace both valve cover gaskets and the valley pan and several other things that might need attention. Replacement of the spark plugs does not require replacement of boots or coils. The pre-cat oxygen sensors should be replaced at 100k as well. Repost if you need more help.
Feb 6, 2009 at 12:11 PM
