2000 BMW 540i Mis-fire, and timing chain tensioner
CHUBBLEZ
  • 7 POSTS
Engine Mechanical problem
2000 BMW 540i V8 Two Wheel Drive Automatic 170xxx miles
2000 540iT
Car: 170,xxx miles
Motor: 64,xxx miles (long block rebuild)
Greetings.
I'm getting a cylinder 1 and cylinder 7 mis-fire when attempting to do any real acceleration (merging in traffic, on-ramps, etc). However, I am un-able to replcate this on-demand. The car was a private party sale, and I've had a pre-buy inspection done. I've had the car for about 2 weeks.
In the inspection, it was noted that the valve cover gaskets are leaking, and the timing chain tensioner needs replacement. I've tried to be reasonably gentile, but if I didn't care about performance, I'd use my '89 accord as a daily driver.
Plugs were done at 170,006. I've checked all 8 coil packs for engine oil in the pack/connector. Most recent attempt (0 miles ago) was swapping packs 1/2, and 6/7. I have not yet driven the car, though it does start w/o error.
The timing chain tensioner looks fairly straight forward, but I'm concerned about skipping teeth, or putting excess tension on the chain. Thoughts?
Jul 14, 2010 at 2:41 PM
DOCHAGERTY
  • 9,606 POSTS
The work you are looking at taking on is quite involved, do you need to have some coaching around that? If you have not done internal work on the M-62 motor, you may wish to seek out a tech that has experience.
Jul 15, 2010 at 2:13 AM
CHUBBLEZ
  • 7 POSTS
[quote:8a9abbb2b9="Dr. Hagerty"]The work you are looking at taking on is quite involved, do you need to have some coaching around that? If you have not done internal work on the M-62 motor, you may wish to seek out a tech that has experience.[/quote:8a9abbb2b9]
From the reasearch I've done the timing chain tensioner didn't look overly involved. Er, well, no more so then plugs or a compression test.
It would appear that I'm missing something, however. Any input you can offer would be greatly appreciated, Dr. Hagerty.
In a strange twist of events, I now have a donor vehicle as well. It's a 2002 540iT. It was a my daily driver before it was rear ended and totaled. My understanding is that most of the major parts (motor, transmission, etc) are interchangable.
Jul 15, 2010 at 5:28 AM
DOCHAGERTY
  • 9,606 POSTS
The M-62 motor at the mileage suggested is prone to issues internally and not just the cam rail tensioner, the cam chain rails are somewhat fragile as they mature and the gasketing material BMW has wisely(?) chosen to use has a definite lifespan, I recommend caution in your diagnosis. The noise, if indeed is just the tensioner and not the rails, then it is an easy job for most and perhaps not outside of your skill sets.
Jul 15, 2010 at 9:00 AM
CHUBBLEZ
  • 7 POSTS
My incliniation at this time is to take the car to BMW NW and have them look at it. To that end, I have an appointment set for Friday the 23rd.
Though sense I've change coil packs (1<->2, 6<->7) I'm now getting a mis-fire on cylinder 4.
What kind of internal work were you thinking needs to be done?
Jul 15, 2010 at 12:01 PM
DOCHAGERTY
  • 9,606 POSTS
I it hasn't already been done, valley pan, valve cover gaskets, intake plate profile gasket and PCV plate, a bulletin about loose oil pump bolts, and several software related problems. This represents the big stuff, the little stuff like window regulators is next.
Jul 15, 2010 at 1:26 PM
CHUBBLEZ
  • 7 POSTS
[quote:cfb0b1dc06="Dr. Hagerty"]I it hasn't already been done, valley pan, valve cover gaskets, intake plate profile gasket and PCV plate, a bulletin about loose oil pump bolts, and several software related problems. This represents the big stuff, the little stuff like window regulators is next.[/quote:cfb0b1dc06]
In 2007 BMW NW put a Bavarian Auto rebuild M62 long block in the car. Is this something that would be normally done in standard maint?
Jul 15, 2010 at 2:45 PM
CHUBBLEZ
  • 7 POSTS
So, I figured I'd post an update.
Having received the car back from BMW NW, I had the following work done - Valve cover gaskets, thrust arm bushings, oil change, coil pack on cylinder 1 & 7, battery, and alternator.
I've also done tires, because someone cut mine.
Jul 29, 2010 at 4:39 PM
DOCHAGERTY
  • 9,606 POSTS
Thanks for the update, how is the car now?
Jul 30, 2010 at 12:15 AM
CHUBBLEZ
  • 7 POSTS
[quote:d5369625ca="Dr. Hagerty"]Thanks for the update, how is the car now?[/quote:d5369625ca]
>:) Fun
Jul 30, 2010 at 7:20 AM
DOCHAGERTY
  • 9,606 POSTS
All good
Jul 30, 2010 at 4:55 PM
