1999 BMW 540i Tech problems
98,507 MILES • V8 • 2WD • AUTOMATIC
KICKINDIRT35
Near the fuel tank, I get a humming noise and as soon as the noise stops it skips. Only does it from time to time, at a crusing speed. No noise on take off. In the beginning had a code 01 dmtl , replaced evap. canister and pump and fuel pump, fixed code still makes noise and skips. Can anyone help?
Mar 9, 2009 at 1:24 PM
DOCHAGERTY
  • 9,606 POSTS
Have you tried replacing he fuel pump relay?
Mar 10, 2009 at 12:34 AM
KICKINDIRT35
Yes, That was stated. Thank you for your help.
Mar 10, 2009 at 3:26 AM
DOCHAGERTY
  • 9,606 POSTS
I must have missed where you stated the fuel pump relay was replaced. Was the main relay replaced too ?
Mar 10, 2009 at 1:20 PM
KICKINDIRT35
[quote:a6cd40f4b7="Dr. Hagerty"]I must have missed where you stated the fuel pump relay was replaced. Was the main relay replaced too ?[/quote:a6cd40f4b7] Yes, We have replaced and tried many things. Nothing fixes it. Any more ideas? Thanks for your help.
Mar 11, 2009 at 5:43 AM
DOCHAGERTY
  • 9,606 POSTS
When you say it skips, do you mean the motor has a misfire or it intermittently stops running for a brief moment, like the ignition was cycled off and then back on again. Has the dealer been involved?
Mar 11, 2009 at 6:28 AM
KICKINDIRT35
It misfires. No dealer. Thanks
Mar 12, 2009 at 4:40 AM
DOCHAGERTY
  • 9,606 POSTS
OK so it's an ignition misfire and not fuel starvation. Have you monitored the main relay, it could be momentarily dropping out. If it is, the electrical portion of the ignition switch has been known to cause issues. Part # 61-32-6-901-962
Mar 12, 2009 at 5:32 AM
