1994 BMW 540i Water pump
1994 BMW 540I
TALLADEGA29
Engine Cooling problem
1994 BMW 540i 6 cyl Automatic
How to change water pump in above car, without removing fuel/intake system. Two rods on the back of water pump hinder my extraction of the pump, and will make it hard to return pump to right location if I have to align these rods with something in the back. what do i need to know to remove pump and install new one??
Dec 31, 2009 at 6:08 AM
DOCHAGERTY
  • 9,606 POSTS
The tubes are coolant pipes, their alignment is possible after removing the coolant pump. Remove the old pump, clean the old gasket off, install the o-rings in the pump and use some lithium grease to aid the installation of the tubes.
Jan 1, 2010 at 1:47 AM
