2001 BMW 540 Check Control Display
60,000 MILES • V8 • 2WD • AUTOMATIC
AROSSWATSON
I recently purchased a used BMW from a private owner. I didn't notice that the Check Control Display LCD doesn't fully illuminate all the characters (letters or numbers). What does this mean and how expensive is it to fix?
Aug 14, 2008 at 10:37 AM
DOCHAGERTY
  • 9,606 POSTS
Pixels missing in the display is quite common for these models and usually does not impact the operation of the vehicle, although it is distracting. The replacement of the instrument cluster is the only thing I can recommend to fix this issue. The replacement cluster will require proper coding and can be completed by the dealer or an independent with the proper software. You may wish to deal with this issue as it is now. The cluster replacement cost isn't cheap, maybe as much as $700, then its installation and coding costs.
Aug 14, 2008 at 12:43 PM
AROSSWATSON
Thanks for the quick answer - I suspected it would be something pricey...so it goes with a BMW. Is there another way I can tell my odometer reading, when service is needed, fluid is low, etc.? And is the cluster replacement in the computer in the turn signal lever or in the dashboard?
Aug 15, 2008 at 8:46 AM
DOCHAGERTY
  • 9,606 POSTS
The odometer is back lighted and you might get the mileage with a key read from the dealer. The instrument cluster will replace as a whole part in the dash.
Aug 15, 2008 at 4:12 PM
AROSSWATSON
Thanks for the great advice!
Aug 16, 2008 at 11:51 AM
DOCHAGERTY
  • 9,606 POSTS
Stop by anytime.
Aug 16, 2008 at 2:13 PM
