1991 BMW 535i Not blowing thru vents
1991 BMW 535I
200,000 MILES • 6 CYL • 2WD • MANUAL
JOHNMELANIE71
I have this BMW the air condition is not blowing thru the vents. However you can here it blowing. I took the dash out as far as i could but did not see any blockage. It sounds like the defrost is on but not sure. No matter how i manuever the switches to turn the front vents on or off it keeps the defrost on. If I turn the air down it does not work you have to keep it on the highest level possible to allow it to work. Thats the best I can explain hopefully you can help
Sep 6, 2010 at 3:29 AM
DOCHAGERTY
  • 9,606 POSTS
Sounds like broken door actuator motor mounts. http://www.realoem.com/bmw/showparts.do?model=HD23&mospid=47408&btnr=64_0127&hg=64&fg=45
Sep 6, 2010 at 3:55 AM
