1986 BMW 535i dragging
KEITH DAVIS
  • 5 POSTS
Brakes problem
1986 BMW 535i 6 cyl Two Wheel Drive Automatic
i am trying to fix a dragging brake problem, i have replaced the pressure regulator,accumulator and pressure switches, bled the power system ihave also bled the brakes, to no avail can you advise me of any thing else i should do or haven't done thank you for any advice keith
Oct 9, 2009 at 4:45 PM
DOCHAGERTY
  • 9,606 POSTS
The anti lock module/pump unit may have an issue. Age and lack of maintenance could possibly cause it to hold pressure in the brake lines, try cracking a outlet fitting and see if that frees up the dragging brakes, if so, replacement might be the next thing. Call Autobahn dismantling @ (619)444-2290, Sean or John will have what you need.
Oct 9, 2009 at 4:55 PM
