1985 BMW 535i fuel cutout
1985 BMW 535I
187,000 MILES • 6 CYL • 2WD • MANUAL
DAVEF
My 85 BMW starts fine, runs for about 20 miles on the highway, then stutters and fails. It will still idle, but not run past 3000 rpm. if it sits for 30-40 minutes, it will run again, sometimes doing it all over again, sometimes not. I have changed the fuel filter, spark plugs and fuel regulator. after I changed the regulator, it ran perfect for 1200 miles, then started all over again. It has 2 fuel pumps, 1 in the tank at the top (the "pre-pump") and the other next to the filter under the car. if this is a pump failing, which one do I start with? any help would be appreciated, thanks! Dave
Aug 5, 2009 at 9:18 AM
DOCHAGERTY
  • 9,606 POSTS
Replace the in-tank pump and both the main and fuel pump relays
Aug 22, 2009 at 2:49 AM
