Hi
Yes I solved the problem. The problem was a white box located in the trunk called MicroPower Module. The fuse map is also located in the trunk near the tool Box, marked with a + sign.
To get on to the Micro Power Module, you have to take out the spare tire; also lift out the black foam part that is on the bottom of the spare tire area. There are 2 white boxes, is the further one. You will notice because the cables are corroded do to oxidation. It looks like water or humidity gets trap there and cause the problem. You have to replace the Micro Power Module and some pins and cables. BMW sell all the parts $185.00 aprox. It looks that BMW knows about the problem, but won’t do a recall. Is not that bad to DIY.
Also there are 2 fuses that have to be replace I don’t recall the number but one is 7.5 amp and the other is a 10 amps (I am not sure but Check #10 & #47 verify the map in the trunk it will lead you to the blown fuses).
To get to the fuses box, unscrew 2 Black plastic screws and pull the Right black trunk cover were the battery is located. The fuses are located right there in top of battery.
Don’t hesitate to email if further assistance is needed.
Julio Aviles
Sep 17, 2009 at 5:09 PM
