2003 BMW 530i rear right door actuator
DECOTABD
Electrical problem
2003 BMW 530i 6 cyl Two Wheel Drive Automatic 65.822 miles
Hello I am curious I have a problem with a rear door that wont unlock by looking at what I could find on the web I think it could be a actuator how can you get the door open to get to it ?? and is there another common part that should be changed when you fix the actuator ?? please reply Thanks Burdette
Dec 19, 2008 at 10:33 AM
DOCHAGERTY
  • 9,606 POSTS
It is tricky to get inside the door panel and release the stuck latch. The door locking assembly will need to be replaced. You will need to remove the door panel and reach up to where the locking assembly is. With a long screwdriver you could force the door to open and as soon as I get my computer back from the repair shop, I can E-mail you the exploded view.
Dec 20, 2008 at 6:39 AM
