2002 BMW 530i Engine misfirre
2002 BMW 530I
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
BILL HERNANDEZ
Engine misfire at low RPM. Changed spark pugs and still missing. OBD II codes show all 6 ciylinders missfiring, plus PO0300 code. Seems to accelerate just fine.
Mar 5, 2010 at 6:33 AM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Mar 5, 2010 at 7:22 AM
