2001 BMW 530i white steam from exhaust
2001 BMW 530I
81,000 MILES • 6 CYL • 2WD • MANUAL
BRIAN530I
in May 2008 the car had a massive amount of white steam coming from my exhaust. as a consequence i had a new cylinder head gasket fitted. since then their has been two occasions when white steam has come from the exhaust, each time it was for only 10 seconds or so after that the car is fine. i checked for water loss in the radiator and found none or verry very little indicating it might not be the gasket or the cylindr block
Jan 27, 2009 at 11:07 PM
DOCHAGERTY
  • 9,606 POSTS
When the engine work was being done and you had the head off, did you have the head checked for cracks? Was it pressure tested?
Jan 28, 2009 at 1:33 AM
BRIAN530I
yes the head was skimed 0.1mm and pressure tested ok
Jan 28, 2009 at 1:43 AM
DOCHAGERTY
  • 9,606 POSTS
It is possible that what you are seeing is just a residual of the trauma of the cylinder head coming off. Keep an eye on it and see if it changes, for now, lets try just driving it for a few days and we can re-visit this conversation then. If the problem persists try an overnight pressure test of the cooling system, that should help to pinpoint the leak, if there is one.
Jan 28, 2009 at 2:01 AM
BRIAN530I
Thank you for your feed back i will take your advice and get back to tou in a few days
Jan 28, 2009 at 2:54 AM
