I already changed the speed sensor on the rear drivers side but still doesn't work what should I do now?
Jun 23, 2009 at 6:03 PM
DOCHAGERTY
✓Experienced Mechanic
The speed signal is generated from the input of the wheel speeds and is sent to the instrument cluster through the DSC control module. That is the module that needs replacement, it will also need to be coded to the car.
