2006 BMW 530 Replacing Rear Rim
2006 BMW 530
KDUFF70
Other Category problem
2006 BMW 530 6 cyl Wheel Drive Type unknown Automatic 39000 miles
My rear Rim has a slight crack which cause me to have a slow leek in my tire which is a run flat tire. I want to replace it with a new rim but after I take the lug nuts off the rim is still held tight I'm sorry to sound foolish but what else is it that is holding the rim in place? I had flats in the front tires before and the rime comes off after taking of the lug nuts out is there something I'm missing to do? I also provide a donation to the cause. I feel its an important source to have alternative information available .
Feb 11, 2008 at 12:27 PM
2CARPRO JACK
  • 11,533 POSTS
Sometimes the center hub gets stuck in the wheel. Install 1 wheel bolt and try kicking the tire from behind to knock it off the hub
Feb 12, 2008 at 10:35 AM
