1985 BMW 528e noise when driving ?
1985 BMW 528E
KERRY7
Noises problem
1985 BMW 528e Two Wheel Drive Automatic
Hi
new here and would appreciate any suggestions. my car is making a strange noise somewhere between a thunking and tinging noise .this only happens when the car is in motion -especially when accelerating? it is coming from the right rear area . we have looked under the car as it is driving and nothing appears loose, have climbed under it and can see anything that could be making this noise,it does not do it if we are at a red light or stop sign.there is no noticeable pulling to either side. if there is anyone who knows what this could be -any help would be very welcome!
thanks so much!!
Oct 1, 2010 at 2:11 AM
DOCHAGERTY
  • 9,606 POSTS
The thing to try here is to get the car in the air on a lift and attempt to determine the source of the noise, I think it might be the driveshaft from your description.
Oct 1, 2010 at 2:17 AM
KERRY7
wow- drive shaft? ok that even sounds expensive... and it is the rear left side -not the right - i dont know if that makes a difference? thank you very much for answering !
Oct 1, 2010 at 2:40 AM
DOCHAGERTY
  • 9,606 POSTS
You're welcome. I request the inspection be performed straightaway before any conclusions are made, it is all too easy to make a bad diagnosis, especially when all the facts are not present.
Oct 1, 2010 at 4:15 AM
