Out of Control Wipers
BMW 528
DORATHEEXPLORER
  • 46 POSTS
I have an 84 528e with wipers that are posessed. They go constant, even with the wiper switch off, unless I pull out the relay. Then dead stop. Any suggestions? Also, the gas gauge doesn't work & the miles per gallon gauge goes crazy, (constantly moving back & forth).
May 11, 2006 at 8:48 AM
2CARPRO JACK
  • 11,533 POSTS
sounds like you need a good electrical guy
Sep 12, 2006 at 5:46 AM
DORATHEEXPLORER
  • 46 POSTS
DUH! If you don't have an answer than no answer is better. Thanks for wasting my time.
Sep 12, 2006 at 5:53 AM
THIS IS MIKE
  • 686 POSTS
Your wiper control module could be bad, but with the other problems you describe the wiring loom should be checked closely for broken or worn wires. It may be a poor grounding problem, so check that too.
Dec 7, 2006 at 3:25 PM
