2000 BMW 528 leaking issue on air conditioner
2000 BMW 528
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARS497
The air conditioner leaking water inside car on passager side.Their's a hose connected to a reserve,then the hose goes under the car.which is connected to a valve then a hose.does that valve need to be replaced to stop water from leaking inside car.A diagram would to. Thank you
Aug 4, 2008 at 7:26 AM
KHLOW2008
  • 41,814 POSTS
Hi cars497,
You need to check the valve and the hose to see if they are clogged or not connected well, which would cause the flooding,
Aug 14, 2008 at 3:38 AM
