2000 BMW 528 Brake pad wear sensor light on instrument pane
50,000 MILES • 6 CYL • 4WD • AUTOMATIC
COOLGPS
How do you turn off the sensor light after the pads are replaced?
Mar 1, 2008 at 10:41 AM
DOCHAGERTY
  • 9,606 POSTS
The lamp is extinguished by turning the key to the KL-15 position(key on engine off) for about 45 seconds, if the sensors were replaced and everything else is nominal, this should take care of the tattletale lamp for the brake pad monitoring.
Mar 3, 2008 at 6:59 AM
