1999 BMW 528 overheating
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOON_DOCK24
beemers overheating and I've took thermostat out and it still overheating. Counld water pump be bad
Mar 25, 2008 at 7:00 AM
  • 75,988 POSTS
Do this fill the radiator leave the cap off-Now start the vehicle and observe the coolant flow is it moving around -now pinch off the upper hose for a few secs and let go-did the flow increse? Also could be clogged-up radiator.
Blown headgasket/cracked head or block:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Mar 25, 2008 at 8:31 AM
