1999 BMW 528 GRINDING
1999 BMW 528
BARBIEHAUBER
Drive Train Axles Bearings problem
1999 BMW 528 Engine Size unknown Wheel Drive Type unknown Automatic 134478 miles
When I turn the wheel either way there is a terrible grinding. also when the car is ideling in park the car cuts off and runs funny is anyone else having these problems so I can get an idea of what it might be? The grinding would that be in my powersteering pump or would it be the axel? The ideling I have no clue.
Feb 21, 2008 at 9:51 AM
DOCHAGERTY
  • 9,606 POSTS
Noises are difficult if not impossible to dianose from cyberspace. The power steering may be low on fluid, check and adjust level with ATF. The idle control issue will require having the system scanned for faults.
Mar 3, 2008 at 3:11 PM
