1999 BMW 528 abs/asc/check engine
JUBUBB
Transmission problem
1999 BMW 528 6 cyl Two Wheel Drive Automatic 115K miles
I'm having isssues with my transmission, when the car is cold the speedometer works for about 5-10 minutes. then it goes to zero, the transmission starts shifting erratic, i can clear the codes, and first to come back on is the p0500 vehicle speed sensor code, then after i start driving for awhile i get another tranmission malfunction code. p174x something but i believe that's only because of the first code, my question is where is the vehicle speed sensor located on this car, or what sensor sends the signal to the speedo??
Apr 19, 2009 at 7:58 AM
DOCHAGERTY
  • 9,606 POSTS
The road speed signal is generated from the DSC/ASC module. It is taken from the wheel sensors.
Apr 27, 2009 at 4:01 AM
