1998 BMW 528 wheel speed sensor
160,000 MILES • 6 CYL • AWD • MANUAL
CRUTCHY
I would like to know where wheel speed sensor A is located on the car.
Aug 8, 2009 at 7:01 AM
DOCHAGERTY
  • 9,606 POSTS
The wheel speed sensors are located at each wheel, they also do not describe them as "A" or so on. It may be relating a wheel speed sensor fault to you and if want to you can swap them side to side and see if the fault moves. I can tell you from experience it may be the control unit and not the wheel speed sensor, even though the fault is being set for a wheel speed sensor. Date of production will clarify part selection and it is vin specific, so you will need that too. 34-52-6-756-343 is $1111.11 from Realoem.com so you may want to try the salvage yards. Try Autobahn in El Cajon (619)444-2290 Dr. Hagerty
Aug 9, 2009 at 6:28 AM
