1998 BMW 528 Rough start when cold only
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEOFFFLOWERS
Need help...Car sputters and vibrates when first start then choke seems to kick in and runs fine. If attempt to start again runs fine but if I leave car off for say 8 hours will have rough start again. Disconnected MAF sensor,O2 sensor, even CTS sensor looking for a different response. perhaps its the fuel filter which hasn't been changed for more than 40K. What do you think.
Signed
Too proud to have OBD scanned
Jan 23, 2008 at 11:15 AM
DOCHAGERTY
  • 9,606 POSTS
An OBDII car is best diagnosed with the correct scan tool. If there is some issue with any of the emissions control equipment you might want to correct it and perhaps then the problem can be resolved.
Jan 25, 2008 at 1:26 AM
PIT456
Hi, I had the same problem with my 528i. It took me weeks to figure out what it was. What you are describing sounds very similar to my problem. Mines turned out to be a faulty Coolant Temperature Sensor. What happens is when the engine is cold the faulty temperature sensor cannot tell the engine it needs a little more fuel to start. This causes the idle to shutter and hesitate. Engines need more fuel when they are cold and a little less when they are warm/hot. This could explain why it only happens when it is cold. I am not saying this is your problem, but it could not hurt to check it out. I took mine to the mechanic and they wanted to charge me $240 to fix the problem. Luckily I figured out it was a $19 Coolant Temperature Sensor that only took about 5 min to replace. The part number I believe is 13621703993. One word of caution is when replacing the switch do not screw it in too tight. The tip is made from hallow copper and if you tighten it too much you will break it right off. Best suggestion, snug, but not too snug. Go to realoem.com type in the part # and get a image of where the temp sensor is located. Good Luck
Feb 16, 2008 at 6:03 AM
