Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
BMW
528
Engine
Mass Air Flow Sensor
Location
1998 BMW 528 airflow sensor
1998 BMW 528
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENT HIGH
MEMBER
Where is the sensor locate and can i do it.
Jul 16, 2009 at 6:46 AM
BLUELIGHTNIN6
Experienced Mechanic
Pretty simple procedure. Located on the air intake
disconnect the sensor connector disconnect vacuum line (if equipped) disconnect air hose clip and clamps on intake filter housing remove intake hose with MAF sensor installation is reverse
Jul 16, 2009 at 6:53 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
