1997 BMW 528 transmission shifting
KEITHT
Transmission problem
1997 BMW 528 6 cyl Two Wheel Drive Automatic
I have a 1997 bmw 528i and when its raining outside or if i go through alot of water nothing more than what would be on the road during a storm the transmission automically takes itself out of drive and goes to S 2 and will not shift back into drive. This will occur until it is dry out and then i have no problem with the car at all. Could there be a connection to the transmission that might in a sense short out because of the connection being bad and then the water hits it?
thankyou
Keith
Jan 29, 2009 at 6:35 AM
DOCHAGERTY
  • 9,606 POSTS
The switch on the side of the tranny does not like water in it, I have replaced them for the issue you are having.
Jan 29, 2009 at 8:11 AM
KEITHT
thankyou for the information on my problem where would this switch be located and what would it be called if you don't mind me asking
thanyou very much for your help
Keith
Jan 29, 2009 at 9:53 AM
DOCHAGERTY
  • 9,606 POSTS
The part # is 24-30-1-423-331 and can be viewed at Realoem.com. It is on the left side of the transmission.
Jan 29, 2009 at 12:10 PM
KEITHT
thankyou very much
keith
Jan 29, 2009 at 1:39 PM
DOCHAGERTY
  • 9,606 POSTS
No worries, come back anytime.
Jan 30, 2009 at 3:47 AM
