1997 BMW 528 sometimes overheats
SURFINEDDIE
  • 1997 BMW 528
  • 6 CYL
  • 225,000 MILES
Have condencation in oil filler cap.
Friday, February 6th, 2009 AT 7:47 PM
DOCHAGERTY
  • 9,601 POSTS
It's not good. Pressure test cooling system overnight with the spark plugs out and see if coolant is getting forced into the combustion chambers, you will know if coolant comes out the spark plug holes. Then you will have to pull the head and have it pressure tested.
Friday, February 6th, 2009 AT 9:59 PM
