1997 BMW 528 radiator
144,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIANCHRIS-82
How can I change the radiator on my 97 bmw 528i
Jan 26, 2010 at 3:29 PM
  • 75,988 POSTS
Removing/Installing Radiator Warning: Danger of scalding. Only perform this work after engine has cooled down. Drain coolant, refer to Cooling System - Service and Repair - Procedures See: Service and Repair Remove fan cowl, refer to Fan Shroud - Service and Repair - Procedures See: Fan Shroud\Service and Repair Note: When removing the fan cowl, note the engine variant.
https://images.2carpros.com/forum/automotive_pictures/12900_rb1_1.gif
If necessary, disconnect plug connection at level sensor. Air conditioning
https://images.2carpros.com/forum/automotive_pictures/12900_rb2_2.gif
Disconnect plug connection on temperature switch.
https://images.2carpros.com/forum/automotive_pictures/12900_rb3_1.gif
Disconnect upper water hose.
https://images.2carpros.com/forum/automotive_pictures/12900_rb4_1.gif
Disconnect lower water hose.
https://images.2carpros.com/forum/automotive_pictures/12900_rb5_1.gif
Disconnect expansion hose.
https://images.2carpros.com/forum/automotive_pictures/12900_rb6_1.jpg
Pull off sealing lip (1) towards top. Release hexagon screws (2) on left and right. Remove brackets (3) on left and right.
https://images.2carpros.com/forum/automotive_pictures/12900_rb7_1.gif
Lift radiator upwards to remove. Installation: Place radiator on supports.
https://images.2carpros.com/forum/automotive_pictures/12900_rb8_1.gif
Installation: Note rubber mounts on left and right sides. Top up coolant. Vent cooling system and check for leaks,
Jan 26, 2010 at 3:45 PM
