1997 BMW 528 passenger front door electronics dead shorted
1997 BMW 528
83,000 MILES • 6 CYL • 2WD • AUTOMATIC
RL2001
the passenger front door haqs no power to it, the lock is set, so cannot open the door, the window has no paower and the power mirror does not work. suspect a short or some other dealing with the wiring and relays to the passenger door. I do not have a electrical diagram for the car.
it is a E39 1997 528I
Dec 27, 2008 at 11:18 AM
The master switch from the driver's side powers all the doors and windows thru an intergrated module/processor
Dec 27, 2008 at 11:59 AM
DOCHAGERTY
  • 9,606 POSTS
Fuses are in the glove box, did you check them?
Dec 27, 2008 at 12:29 PM
Hey Doc its your kind of vehicles take it from here holler if you need me
Dec 27, 2008 at 12:52 PM
RL2001
sorry took so long to get back , went through all the electrical, no blow fuses, no shorts, saw that another pwerson has a 1999 doing the same as my 97, you suggested removing the door panel. from what i am told by BMW local shop this will require tearing up the panel to access the actuators and unlock the door and troubleshoot the rest of the electronics in the door. any better idea than tearing up a 500.00 dollar door panel.
Feb 15, 2009 at 6:14 AM
That's my only way out of testing it, is to it take apart one way or the other it has to be fix-Sorry I have no other idea
Feb 15, 2009 at 7:40 AM
DOCHAGERTY
  • 9,606 POSTS
If the door is completely dead and the panel might be damaged during discovery, try sourcing a replacement panel from a salvage yard. I am aware of what you are going through and I wish I had a magic bullet, but if the actuator is dead, there really is only one way to go, and that might require a replacement door panel. Try Autobahn salvage @ (619)444-2290, they do only BMW and PORSCHE.
Feb 15, 2009 at 9:09 AM
RL2001
afterlooking at the messages and looking at mitchell1 i registered there and looked over the wiring diagram. then went to ebay to find prices on the panels and parts. one thing to note the curtesy light still works. leading m,e to think its the door module located under the panel. thought Ford has some piss poor designs. but BMW takes the cake on this one.
The bulb is not bright
Feb 15, 2009 at 10:24 AM
DOCHAGERTY
  • 9,606 POSTS
You said it brother. I wonder if anyone at BMW is listening to this.
Feb 15, 2009 at 11:36 AM
