1997 BMW 528 Oil level sensor
ALLHOBBS
Engine Mechanical problem
1997 BMW 528 6 cyl Two Wheel Drive Automatic 150K miles
Hi my oil level sensor unit is leaking oil do you think it is the unit or the seal/gasket leaking?
May 12, 2010 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely the gasket but once you remove the unit you should be able to tell if the gasket is good.
May 12, 2010 at 3:44 PM
