1997 BMW 528 Driver window is stuck in the down position.
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BAKERJ36
Is there any way to raise the glass so I can access the regulator and motor?
The glass or the door block access to the screws and bolts to get at the release points.
Apr 27, 2009 at 3:31 AM
DOCHAGERTY
  • 9,606 POSTS
You should be able to take the door panel off, then the vapor barrier and the regulator should then let you raise the glass by hand, since it seems the cable is broken, if not the cut the cable and proceed with the window regulator replacement.
Apr 27, 2009 at 3:55 AM
