1997 BMW 528 97 528i RPM's running high after transmission
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
TX528I
I recently had my transmission rebuilt and now the RPM's seem to be running a lot higher than before. For example, at 70 MPH, the RPM's are around 2700-2800. If memory serves me correctly, before they were down around 2000 to 2100. Does the computer need to be reconfigured or reset to reflect the rebuild? Also, the neutral safety switch was replaced during the rebuild.
Aug 16, 2010 at 2:34 AM
DOCHAGERTY
  • 9,606 POSTS
Rebuilt transmissions for that car can be bothersome in as much as the matching of the control module to the tranny. Is the warning indicator illuminated? It sounds like the TCC might not be locking up at speed.
Aug 17, 2010 at 2:23 AM
TX528I
No, there is no warning indicator light illuminated. Other than running at the higher RPM's, the car seems to be driving normally. I am just concerned about the wear on the engine and poor gas mileage.
Aug 18, 2010 at 8:47 AM
DOCHAGERTY
  • 9,606 POSTS
Where did you get the rebuild done?
Aug 18, 2010 at 11:40 AM
TX528I
A local shop that specializes in transmission rebuilds. Couldn't afford the dealership for a 97 with 200,000 miles on it.
Aug 19, 2010 at 1:50 AM
DOCHAGERTY
  • 9,606 POSTS
First thing I would do is go to the rebuilder and express your concerns. They should be willing to address this issue straightaway.
Aug 19, 2010 at 2:08 AM
