1988 BMW 528 power windows stop working
198,000 MILES • 6 CYL • 2WD • AUTOMATIC
FJ0094
  • 12 POSTS
all 4 power windows just stop working , i was driving and all windows was working then at one point i try to open them again nothing happen . Thanks for you help Frank problem #2 car will not start on a Hot Day runs ok travel a few miles Park go back to the car it will not start wait a while it just start like that.
May 2, 2010 at 8:18 AM
DOCHAGERTY
  • 9,606 POSTS
Check the fuse and the circuit breaker and let me know!
May 2, 2010 at 3:33 PM
FJ0094
  • 12 POSTS
i have already go through the fuse checking, where do i find the circuit Braker ?
May 3, 2010 at 10:00 AM
DOCHAGERTY
  • 9,606 POSTS
It is mounted in the under dash panel in the drivers footwell area.
May 4, 2010 at 3:21 AM
FJ0094
  • 12 POSTS
Thanks DR i have found the braker it was trip indeed
3 of the windows is working fine now the driver side front button is the one tripping the braker so that window is not working it keep tripping the braker a switch around the buttons so its not a bad button
Regards Frank
May 5, 2010 at 10:04 AM
DOCHAGERTY
  • 9,606 POSTS
So its the wiring or the motor mate, you seem to have it handled.
May 5, 2010 at 12:00 PM
FJ0094
  • 12 POSTS
could you point me to the Motor Mate Please
Thanks Frank
May 6, 2010 at 9:38 AM
DOCHAGERTY
  • 9,606 POSTS
Remove the door panel Frank.
May 6, 2010 at 4:30 PM
FJ0094
  • 12 POSTS
Thanks all is ok now windows are fine
Frank
May 7, 2010 at 12:35 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
May 10, 2010 at 8:48 AM
FJ0094
  • 12 POSTS
Do you know of any place where i can get Body Panels/Restoration panels if so can i have the the info please
Thanks Frank
May 14, 2010 at 8:53 AM
DOCHAGERTY
  • 9,606 POSTS
Autobahn dismantling @ (619)444-2290
May 15, 2010 at 2:26 PM
