I now own a second hand 1988 BMW 528e. The car is in great condition and i love it except that it doesn't run for long.
When I drive the car runs without issues until the speedometer starts to go crazy as well as a few other gages. Within minutes of that happening the cart stalls and cannot be started without a jump start or charging the battery. Allowing the car to idle or to drive with everything off allows the battery to recharge.
I have not been able to isolate where the drain is.
Can you provide me any guideance on where BMW's may have had a shorting problem, or any information on what you think the issue is.
I have checked for current draw at the fuse box in the engine compartment and cannot find a circuit that is draining while the car is off.
The issue must be a high drain to make the battery go dead whilr the charging system id running. I have a new battery and alternator and still the same problem.
Thanks for any help you can provide.
Dave Jalbert
401 615 3353
Dave Jalbert
401 615 3353
Oct 22, 2008 at 3:27 PM
