1988 BMW 528
AJAV05
1988 BMW 528
I have a 528 BMW 1988 and the car will not pass inspection because the NOX is to high I changed O2 sensor and spark plugs (I used platinum plugs) and still did not pass any sugesstion?
May 25, 2008 at 11:49 AM
DOCHAGERTY
  • 9,606 POSTS
How old is the cat? Knowing how to interpret the emission gases can help diagnose a cat that is ready to be recycled. Is there excess carbon deposited in the combustion chambers? Try a little water injection to reduce carbon build up. Install the stock spark plugs, Bosch W8LCR gapped to .028" Set the valve lash @.010" with the engine cold.
May 27, 2008 at 3:37 PM
AJAV05
I did change the cat about a year ago
May 28, 2008 at 10:26 AM
DOCHAGERTY
  • 9,606 POSTS
Was the replacement an original equipment cat from BMW?
May 29, 2008 at 2:41 AM
AJAV05
No it was aftermarket
May 29, 2008 at 11:27 AM
DOCHAGERTY
  • 9,606 POSTS
It is probably a two bed cat and it will not work to remove the NOX as well as the three bed cat that is a stock item. Replace the cat with a original equipment cat and that should do it.
May 29, 2008 at 1:36 PM
