2005 BMW 525i engine noise while running
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARIBBEANDIVER42
hi I have a 2005 bmw525i it was running fine the night before,parked it and started the folliowng morning,it back fired 3 times, so lou.d that the nieghbors thought there was a explosion.......
now it starts,runs rough,and sounds like a popcorn maker in the rear 2 or 3 cylinders,the check ebgine light is on, but my snap-on solus scanner has no communication with the car,all the fuses in the trunk and glove box area are hot...i'm sure I could find the problem easier if I knew what the check engine light discloses but what to do.. Has anybody heard of this crazy problem.
Apr 29, 2009 at 11:21 PM
DOCHAGERTY
  • 9,606 POSTS
It might be the cyclone separator has failed. OBDII communication is not always possible with generic scanning equipment. The part# for the separator is 11-61-7-501-566 and can be seen in exploded view @ Realoem.com ♥
Apr 30, 2009 at 4:33 AM
