2003 BMW 525i a/c stopped working
2003 BMW 525I
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
EARTHWORKSCONCRETE
a/c stopped working, new blower motor, new fs unit, used light tester, good @ blower motor, good @ fs unit, lights of control panel light up, need help, also checked fuses
Sep 12, 2010 at 7:13 AM
DOCHAGERTY
  • 9,606 POSTS
How can you be sure the final stage unit is working, did you test it against another known working final stage unit?
Sep 12, 2010 at 2:46 PM
EARTHWORKSCONCRETE
thank you i don't know, how can i test the final stage unit
Sep 14, 2010 at 9:16 AM
DOCHAGERTY
  • 9,606 POSTS
A comparison against a known good working unit is the only test I can recommend due to the fact you have no way to compel the blower fan on with proprietary software. If it is a used unit with LARGE tapered heat sink "teeth" it is questionable.
Sep 15, 2010 at 1:35 AM
