2002 BMW 525i oil burn!!!
90,000 MILES • 6 CYL • 2WD • MANUAL
MAGIC2583
just bought this 525 i 2002 with lots of hidden problems. first it burns oil. did the compression test. cyl1 180, cyl2 175 cyl 3 160, cyl 4 165, vyl 5 170, cyl 6 125!!!! i did engine flush with bavauto recommended lubro moly. it looks like it stopped blue smoke from puffin but is still consumes oil. i never replaced the oil separator and hoses around it. mechanic told me that they were fine but i read that at this milage it has to be done, period. now i did the ligh engine check and it said something about, post catalyst fuel trim bank1 1 too lean, and some misfire 1, and something about fuel low. i had also fuel injectors cleaned when I bought is and valve cover gasket replaced, and spark plugs replaced. please tell what are my options??
Jul 10, 2009 at 8:03 AM
DOCHAGERTY
  • 9,606 POSTS
Replace the cyclone seperator and reset the adaptations and your oil consumption should get better.
Jul 11, 2009 at 4:55 AM
MAGIC2583
did crankcase vent. system job and it did not improve. still burns oil.......
Jul 20, 2009 at 2:05 PM
