2002 BMW 525i Driver side door lock
78,000 MILES • 6 CYL • 2WD • MANUAL
NECYANN89
To whom it may concern:
My alarm went off last night and it totally drained my battery. As a result, I am unable to unlock my car door and trunk. My key is supposed to unlock my driver side door, but it is not working due to power failure. My question is: Do you know of any other way to charge my battery, so that my central locking devices works? Any help that you provide would be highly appreciated. thanks.
Adrian
May 13, 2009 at 1:20 AM
DOCHAGERTY
  • 9,606 POSTS
The key can be inserted into the lock of the drivers door, then lift the handle and then turn the key to unlock, also the key should open the trunk even if the central locking is inoperative.
May 13, 2009 at 5:19 AM
