2001 BMW 525i TEMP GAUGE
70,000 MILES • 6 CYL • 2WD • MANUAL
ASVRUDEBWOY
Each morning or after my car is parked for an extended period, the temperature gauge goes up to the red zone and then after 5 or so minutes would go back down to normal. The colder the outside temp the longer it takes to go to normal, please let me know what could cuase this problem. I recently changed the radiator, thermostat, water pump and associated accessories.
Thanks
Arron
As per above I did state each morning, meaning the engine would be cold, on moving off it would rise to normal then to the red zone stay there for about 5 minutes then back to normal.
Thanks
Mar 15, 2009 at 4:34 AM
DOCHAGERTY
  • 9,606 POSTS
I dont understand. When does the gauge go to the red zone, after you start the car from cold it goes to red or after it runs for a while? Did the cooling system have all the air bled out when the replacement work was done? How long has this gone on?
Mar 15, 2009 at 10:17 AM
