1995 BMW 525i Trans Problem!
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
SRPORTERJR
I have a 95 525i if i drive the vehicle over 50 mph the dash computer shows a Trans problem message. I have read the owners manual and it tells you that the Transmission Control Module is bad and needs to be replaced. I have replaced it with three rebuilt modules and it continues to do the same. It will shift fine up to third gear but then will not shift any further and then will show the same message. Anyone firmilar with this problem????? need help!!!!!
Jan 4, 2010 at 5:20 AM
DOCHAGERTY
  • 9,606 POSTS
It seems as though the EGS brain is not at fault if 3x replacing it does not do anything. The fault may be in the transmission or it might need a chip for the transmission brain. Where did you source the modules from?
Jan 4, 2010 at 7:29 PM
SRPORTERJR
I was using a company out of Jacksonville Florida. The last module they sent the shift timing
are different and it doesn't throw the Trans Problem code as often. It still won't shift into the higher gears..
Thanks,
S. Porter
Jan 5, 2010 at 3:41 AM
DOCHAGERTY
  • 9,606 POSTS
There are some numbers I need from you, first I am going to speak to my source at this end, stand-by.
Jan 8, 2010 at 12:49 AM
DOCHAGERTY
  • 9,606 POSTS
Can I get the numbers off the trans computer? Also the image of the ID plate on the tranny too.
Jan 8, 2010 at 11:38 PM
