1995 BMW 525i Tight Steering
160,000 MILES • 6 CYL • 2WD • MANUAL
SUJIT
Yesterday I was driving and all of a sudden by steering became very tight. The belt from the engine seems to be missing and the battery light on the dash turned on.
I think the below belt is what has fallen off.
Serpentine Belt/Ribbed Drive Belt; Alternator/Power Steering/Water Pump
Does this mean that there is one belt that runs the Alternator, water pump, and power steering? If I dont get this fixed right away does this mean the coolant isnt going to run through the engine and it may overheat?
How much does it cost normally to get this belt installed?
Thanks,
Suj
Dec 21, 2008 at 4:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, you need the belt replaced ASAP. The belt replacement shouldn't run you more than $125.
Dec 21, 2008 at 4:14 PM
