How do you reset the factory alarm system if the initializing of a new key transmitter fails?
Nov 11, 2009 at 12:13 AM
DOCHAGERTY
✓Experienced Mechanic
Can you tell me the initialization steps that you took?
Nov 11, 2009 at 1:05 AM
TARTOBY
MEMBER
[quote:2edc69b805="Dr. Hagerty"]Can you tell me the initialization steps that you took?[/quote:2edc69b805] I followed the directions of the owner's manual; I pointed the factory key toward the transmitter, held button #3 while depressing button #1 three times after performing the ignition position functions.
Nov 11, 2009 at 3:03 AM
DOCHAGERTY
Send the last seven of the VIN, your car is in a transitional year for that model, I need to ID the car.
Nov 11, 2009 at 2:47 PM
TARTOBY
MEMBER
The VIN is WBAHD5329SGB39202. Thanks for your help!
Nov 11, 2009 at 11:05 PM
DOCHAGERTY
The factory alarm for the E34 cars was not in the key, but in a remote fob. That initialization procedure should be to disconnect the alarm module for 30 seconds. If no joy, call John at Autobahn dismantling,(619)444-2290 He will guide you.
