1993 BMW 525i Ignition Key Lock Cylinder
PHOTON
Steering problem
1993 BMW 525i 6 cyl Front Wheel Drive Automatic
How would I go about removing the key lock cylinder from the housing?
Aug 31, 2010 at 5:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
1.Insert the ignition key and turn 60 degrees.
2.Use a 3/64 inch (1.2mm) wire to press down into the small bore on the face of the lock.
3.Pull the lock cylinder out.
4.If there is no bore, remove the steering column trim and press the bore on the side of the cylinder with punch to remove the cylinder.
5.Installation is the reverse of removal.
Aug 31, 2010 at 6:15 AM
