I stopped the car and the ignition would not go off, key would not come out easily. After strugling for a while the key came out but the iginition was still on and the indicator said ignition is on. When I tried to put the key back in, I had trouble putting key in ignition. I turned key and car was dead. Battery checked out ok. Do I need to replace the steering lock and do I need to tow the vehichle to a repair shop or can this be repaired without being towed to the shop.
Earlier suggested solution on this forum seems to be applicable to this problem as well
Replacement of part #2 in this link: http://www.realoem.com/bmw/showparts.do?model=HD63&mospid=47404&btnr=32_0906&hg=32&fg=30
But wanted to know if the car needs to be towed or can be repaired where it is parked now.
Apr 23, 2010 at 7:44 PM
