1991 BMW 525i SUNROOF
275,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIMANDJAY
MY PROBLEM , THE SUNROOF IS STUCK IN THE OPEN POSITION , IS THERE AWAY TO CLOSE IT MANUALLY , UNTIL WE CAN HAVE IT REPAIRED .
Feb 27, 2009 at 1:55 PM
DOCHAGERTY
  • 9,606 POSTS
I believe in the owners manual there is a method with a 4mm Allen wrench after the motor is exposed. Is the motor not working? I know those sunroofs, and if it is stuck open because of a broken part or a parted cable, then the cassette must be removed for inspection and that means the headliner needs to come out.
Feb 27, 2009 at 4:45 PM
