MY PROBLEM , THE SUNROOF IS STUCK IN THE OPEN POSITION , IS THERE AWAY TO CLOSE IT MANUALLY , UNTIL WE CAN HAVE IT REPAIRED .
Feb 27, 2009 at 9:55 PM
DOCHAGERTY
✓ASE Certified Mechanic
I believe in the owners manual there is a method with a 4mm Allen wrench after the motor is exposed. Is the motor not working? I know those sunroofs, and if it is stuck open because of a broken part or a parted cable, then the cassette must be removed for inspection and that means the headliner needs to come out.
Feb 28, 2009 at 12:45 AM
