1990 BMW 525i valve rocker arms adjustment order
1990 BMW 525I
BLY
Engine Mechanical problem
1990 BMW 525i 6 cyl Two Wheel Drive Automatic 146.oo miles
i need to know what order is the valves are adjusted after you have number one set . is it two , three , six this is what i need to know . and when i rotate to camshalf what number order when i need to adjust the other three valves.
Jul 23, 2010 at 8:22 AM
VALVE CLEARANCE ADJUSTMENTS
Adjust valves in firing order (1-5-3-6-2-4), with piston of cylinder being adjusted at TDC of compression stroke. Use a feeler gauge to measure clearance between rocker arm eccentric and tip of valve.
To adjust valve clearance, loosen nut on rocker arm and insert a rod in eccentric hole. Rotate eccentric until proper clearance is obtained and tighten lock nut.
ApplicationIn. (mm)
Intake & Exhaust
Cold.010 (.25)
Hot.012 (.30)
Jul 23, 2010 at 11:02 AM
