Well, one way would be to obtain a cooling system pressure testing pump and the appropriate adapters. Or to fill the system, open the bleeder screw on top of the thermostat housing and fill the system until all the bubbles stop and close the bleeder, top the system off, cap it and start it up with the heater to full hot. Find the leak b4 you put coolant in, just use water until you're sure it's fixed, then drain the system and refill with coolant/water mixture.
SPONSORED LINKS
Sunday, August 23rd, 2009 AT 2:26 PM
